JM_16v Posted November 27, 2008 Posted November 27, 2008 i assume they all work the same by lowering the voltage returned from the map sensor, so if thats the case then will an mr2 one work on the glanza Quote
Glanza_Ragger Posted November 29, 2008 Posted November 29, 2008 Ive got a theory..FCD's = BANGWhat are you using to up the fuelling past fuel cut if you were to fit one? Quote
