guna use my standard gearbox for a while, and mount it to a 4efte.. however i need a new clutch. now im on the understanding that the 4efe clutch is different to the 4efte ( so im told ), so if i get an upgraded clutch for an N/A gear box will it fit on the Turbo flywheel? or does it need to be a turbo clutch?!
if anyone knows how many splines the turbo clutch and the N/A , this will help me greatly as well!!
If using the 4efte flywheel you will need that clutch
exactly as dave said, if you have a 4EFTE engine you will need to use a 4EFTE clutch.
hi mate, would the 4efte clutch fit onto/into the gear box? like say i fited the 4efte clutch to the fly wheel then put the N/A gear box on it, it would all fit and run properly?!!
straight from the oracle B) say no more B)
sound lads, sorted that one out! put a smile on me face now! ive posted a few other things about it, for fuel pump, and cnt remember other thing, but any help with them i wud greatly apreciate it!
