AlexGTAdv Posted December 15, 2008 Posted December 15, 2008 Hi guys, yet another bloody gearbox question Does anyone know if the Glanza S boxes are the same as the Glanza V and GT boxes?? I was kinda thinkin they might be as the Glanza S is more powerfull than the Uk spec NA's so was thinkin that the crazy japs may have put the turbo version box in?? Or does anybody know if the Glanza S box would fit my GT? Would the ratio's be different?Cheers again Quote
Idrees Posted December 15, 2008 Posted December 15, 2008 Check the code on it buddy, or ask the seller to..If I remember correctly.. C52 is a GT box and C56 is from a Glanza V. Quote
AlexGTAdv Posted December 15, 2008 Author Posted December 15, 2008 Check the code on it buddy, or ask the seller to..If I remember correctly.. C52 is a GT box and C56 is from a Glanza V.Cheers bud, i thought the Glanza V and GT shared the same box, i assume they will work on either any ways?? Quote
Idrees Posted December 15, 2008 Posted December 15, 2008 Yeah they do work on each other but the gear ratios slightly differ. Quote
AlexGTAdv Posted December 15, 2008 Author Posted December 15, 2008 Yeah they do work on each other but the gear ratios slightly differ.Ok, so jus thinkin, surely the 4EFE has the same block as the 4EFTE? This should mean it would fit no? Quote
AlexGTAdv Posted December 15, 2008 Author Posted December 15, 2008 Cheers for that mate, unfortunatly that doesn't really mean much to me lol i can see from that that 2nd and 5th are the same. Would i notice a change if i put the S box in my GT, like a change for the worse plus would it just bolt straight in? Cheers Quote
