200sx-Starlet-Jay Posted December 22, 2008 Share Posted December 22, 2008 alright peepsright as posted in other threads i have my self a 4efte, and i am adding on quite a few of the stage 1 tuning gear available. if i leave the turbo alone with all the bits i have been told it is going to hit fuel cut and all other sorts of bob. so i may as well add the turbo into the equation and raise the boost. so.. question at hand is how do i go about raising the boost? and what sort of kit do i need?i take it a FCD for a start, then will i need an actuator and just adjust the actuator? or do i need a bleed valve or boost controler as well? need to know asap people so the more help the better, wanna close a deal tonite if possible!! Quote Link to post Share on other sites
Glanza_cl Posted December 22, 2008 Share Posted December 22, 2008 this is a super crude way of doing it and can result in you just blowing your engine but...you need a FCD a RRFPR and an adjustable actuator or a EBCthe FCD will remove fule cut,the RRFPR will add the extra fuel so you dont run leanand the Actuator or EBC will raise the boost level.IF DOING THIS IT WILL NEED SETTING UP ON A RRi highly don't recommend doing it this way but it is your car.people do it and dont have problems but they tend to add uprated fuel pumps and at least a AVCR to set some kind of fuel map Quote Link to post Share on other sites
200sx-Starlet-Jay Posted December 22, 2008 Author Share Posted December 22, 2008 Glanza_cl said: this is a super crude way of doing it and can result in you just blowing your engine but...you need a FCD a RRFPR and an adjustable actuator or a EBCthe FCD will remove fule cut,the RRFPR will add the extra fuel so you dont run leanand the Actuator or EBC will raise the boost level.IF DOING THIS IT WILL NEED SETTING UP ON A RRi highly don't recommend doing it this way but it is your car.if i took it to a rolling road, do they charge for the hour or is it just a set price?Jaypeople do it and dont have problems but they tend to add uprated fuel pumps and at least a AVCR to set some kind of fuel map Quote Link to post Share on other sites
glanza87 Posted December 22, 2008 Share Posted December 22, 2008 Just what glanza_cl said. Its a more simple way of upping the boost. For a start you can up the boost to 0.8 bar without hitting fuel cut, but this also depends on what you are running like fmic, decat etc...Also you wont want to be putting the boost up too much if you are running a standard mani as the 3rd runner is restricted and you could do damage to your third piston!Regards Johny Quote Link to post Share on other sites
200sx-Starlet-Jay Posted December 22, 2008 Author Share Posted December 22, 2008 glanza87 said: Just what glanza_cl said. Its a more simple way of upping the boost. For a start you can up the boost to 0.8 bar without hitting fuel cut, but this also depends on what you are running like fmic, decat etc...Also you wont want to be putting the boost up too much if you are running a standard mani as the 3rd runner is restricted and you could do damage to your third piston!Regards Johnyno i have an after market mani fitted already, so if i jsut got the fcd and fitted it with out raising the boost, would it creep over .8 bar u reckon? just would idealy like to get it running and make sure its a sound lump and not a dog before i start wackin it up! Quote Link to post Share on other sites
