Guest 180kph Posted December 24, 2008 Posted December 24, 2008 Im try to make sure i can control the boost on the TD04 before i got back up for mapping, basically if i set it for .6 it'll creep to .65 but when it hits this boost it bogs down for a few seconds, not the actual car just the boost,seems to be restricted.Then if i set it for .8 it will creep to .82bar and the same boost bogging again And at 1bar it goes to .77:confused:It seems to be restricted,maybe chris put a restriction on the ecu on the intial set up (emanage blue) and im using the blitz sbc.And the revs dont go up when the "bogging" happens.Dan Quote
Guest 180kph Posted December 25, 2008 Posted December 25, 2008 Noticed boost doesnt come fully until maybe 4.5k And the acuator is held on via one bolt,could that be it?Got 25 on the diagnostics,running lean? Quote
