  laker said:
the diff between an ep and non ep I've just bourght a starlet need to as have gota get new bits all i no is its a 93 starlet gt turbo
both turbo models are of the ep code.you have the ep82 which by the age is wot u have.is it a square light or quad light and then u have the ep91 or glanza which was made from 1996 onwards.most parts are interchangeable but others are model specific.hope this helps
