4efte_ryan Posted January 10, 2009 Posted January 10, 2009 if i unplug the idle control valve whilst the car is running should the idle change at allcheers ryan Quote
4efte_ryan Posted January 10, 2009 Author Posted January 10, 2009 oh ok because my revs stay the same when i unplug it, i have been having idle probs, would you say the icv is wankered then? Quote
paulgtt Posted January 10, 2009 Posted January 10, 2009 When I had my GT it would idle quite high so unplugged the IAC valve and it would idle a bit lower (for a second or so) and then stall. I just sprayed a very small amount of carb cleaner into it and plugged it back in, seemed to idle alot better after that. Quote
4efte_ryan Posted January 10, 2009 Author Posted January 10, 2009 well when i unplug it it doesnt do anything the revs just does the same and i have already cleaned out the icv out and tried to adjust the idle with the screw and no difference, my glanza is idling at 2000rpm its pretty bugging me now, gonna try a diag test now see what that comes uo withcheers ryan Quote
