Kennedy Posted January 23, 2009 Posted January 23, 2009 Hi Guys,Couple of questions..what it is as far as i am aware nothing has been change on my turbo apart from the EBC n a dump valve..but my boost level goes up to 0.93 bar on the EBC (i need to get a decent boost guage ) i have hit fuel cut and have had the engine managment light come on What i was wondering..does an actuator limit boost? as i take a boost controller can't?If it does and i get 1 are they hard to fit?Are they hard to setup?if i set the actuator to say 0.85 and the EBC to 0.9 would the actuator over ride the EBC and boost would only reach 0.85?and lastly, is there a specific one for the CT9 that i should look for/get?Thanks in advance guys Quote
Kennedy Posted January 23, 2009 Author Posted January 23, 2009 Ok mate that makes sense..so reading that i take it the actuator will over ride the ebc and you can only boost up to where the actuator is set to and not the ebc? Quote
Kennedy Posted January 23, 2009 Author Posted January 23, 2009 ok thanks..is there a way to limit your boost?or would you need an after market ecu? Quote
Glanza_cl Posted January 23, 2009 Posted January 23, 2009 that's what the HKS actuator does it sets the boost to one level and one level only- e.g. 0.6 the boost can not raise any higher then that (unless you use the ebc) as that is what the actuator is set at.the only way boost rises is boost creep (nothing to do with the actuator)or an ebc with raises the boost level electronically but cant go lower then the HKS boost level as the actuator sets the 'original' boost level Quote
Glanza_cl Posted January 23, 2009 Posted January 23, 2009 no problem hope you get it all sorted Quote
