JM_16v Posted January 27, 2009 Posted January 27, 2009 :| car makes a high pitched noise on boost. very small boost leak through the dump valve, so small it doesnt affect it holding the presssure thou luckily, i need a reducer 20-35mm any ideads? Quote
andy.i Posted January 28, 2009 Posted January 28, 2009 might dohttp://cgi.ebay.co.uk/STRAIGHT-REDUCER-SIL...Q2em118Q2el1247 Quote
JM_16v Posted January 28, 2009 Author Posted January 28, 2009 wonder if it will stretch enough? the pipe diameter itself is 35mm let alone the lip Quote
andy.i Posted January 28, 2009 Posted January 28, 2009 stick the pipe in the freezer and the reducer in hot water, should do with a push Quote
Glanza-Love Posted January 28, 2009 Posted January 28, 2009 tighten the jubile clip.. if its at its tightest.. then renew it see it that saves the bother Quote
