right i have a ep82 and it when im at idle about 30 seconds later i get blueish smoke coming out the exhaust, when i drive off its gone, ive been searching around i have found it could be either the turbo, valve stem seals or pcv? is there anyway of telling which 1 of these it could be?
cheers
Check the turbo,if it aint the turbo its your valve stem seals
what do i check it for mate? sorry im new ie only had the starlet a week?
has anyone got a pic of where the pcv is located and what do i check that for? how much is a new one? sorry if i seem a bit thick.
About £20 for a new one, it's on the cam cover. Theres a pipe going from that straight to the inlet manifold. Might be under your intercooler though unless you have a front mount.
As some one has said above, it could be your turbo seals too. Same thing happened with my cousins.
yer ive got a front mount intercooler, ill have a look in a bit im at college at the moment, can i get the pcv from toyota or do they have to import it? cheers
Play mate,if its got loads of movement in and out and up and down when holding the turbine by the centre then its fooked mate
not always.... not always valve stem seals either... could be rings or internal damage or pcv valve
argghhh gutted if its internal damage!!!! shall i just take it 2 the garage and see what they say??? because i dont have a clue on how to checks whats wrong with it??
  • 2 weeks later...
