barnz18 Posted February 1, 2009 Posted February 1, 2009 im new and have a blitz dual sbc type s fitted into my car (its an ep82) and i dont have a clue how to use it it, can anyone tell me what each setting means and does and how to set it up to change the boost, when the turbo kicks in at the moment it goes up 2 10psi if that helps. thanks. Quote
Kennedy Posted February 1, 2009 Posted February 1, 2009 Theres sum instructions on the internet somewhere..some1 posted them up for me.see if i can find them for you mate Quote
barnz18 Posted February 1, 2009 Author Posted February 1, 2009 Theres sum instructions on the internet somewhere..some1 posted them up for me.see if i can find them for you mate cheers mate Quote
Kennedy Posted February 1, 2009 Posted February 1, 2009 Some instructions here if needed:http://www.blitz-performance.com/includes/...c%20S&R.pdfthis is quite good as well:http://www.geocities.com/MotorCity/Speedwa...sbc_manual.htmlThis is for the type r model but sure they work the same Hope it helps Quote
barnz18 Posted February 1, 2009 Author Posted February 1, 2009 This is for the type r model but sure they work the same Hope it helpsthe links didnt work mate? Quote
barnz18 Posted February 1, 2009 Author Posted February 1, 2009 cheers mate ill have a go in the morning, so the psi will go up when i set the sbc up correctly? sorry if i sound thick im a newbie. Quote
Kennedy Posted February 2, 2009 Posted February 2, 2009 Ye..the higher you turn it the more boost will increase.I'd turn it up slowly though so you dont hit fuel cut. Quote
