Hi all, i have 2 shafts from old 82 so i can fix 2 knackered outer joints on my glanza. I know they are different lengths but i was just aiming to split the shaft down. the problem i have is that the shafts from my 82 are non abs where as the glanza has abs rings on their outer cv joints. Can the abs rings come off and go onto the 82 joint or will i have to get a glanza cv joint?
Hope that made sense!
Cheers
Jonny
Hello mate. I did my mate's CV boot the other day and from what i can remember the abs notches are part of the joint itself so unfortunatly you're going to have to find some glanza cv joints, unless the gt cv joints you have are abs as some gt's came with abs! Good luck.
Alex
