Callan Posted February 4, 2009 Posted February 4, 2009 right i want to clear this up as it seems not to of been explained on here in a sticky, so il startFUEL CUTFuel cut is where your stock ecu limits the boost pressure to a maximum of 12-15 psi (it will be different on cars with a different turbo setup BUT you should have a fuel cut defencer and fuelpressure regulator for this)This can be caused by simply changing your air filter or exhaust system to a better free flowing item or can even be caused by cold weather as the air is more denseThe way to get rid of this fuel cut is to fit a manual 'hks' fuel cut defencer or self setting 'JAM-Greddy' boost cut controllerThese are simple to fit and will get rid of any fuel cut issues, however on stock turbo 15-17 psi is the safe maximum limit, Also if raising boost to a safe level eg. 1 bar (14.7 psi) the standard actuator will not be able to hold boost andwill drop off, a Toytuning actuator or a HKS actuator will be neededSPEED CUTThis is where the speed of your car after 112mph/180kmh is limited, in japan they make all factory cars limited to that speed, if you wish to remove this limit a mechanical speedo convertor will need to be purchased, this also makes your clocks into MPH and is very simple to fit, PM me or MsN if any questions about thatIf your speedo is out byt this, this could be due to after market wheels changing your speedo, but thats a different kettle of fishany questions cosworthcal@msn.com or PMCheeRS.CaL Quote
