If i put a de-cat, full ehxust, air filter and FMIC on my glanza, will i have issues with fueling or will it run fine and not explode?
If it would have fueling probs, what could i do to correct it?
i just want more from the glanza and im worried as ive never had a turbo car.
replies welcome,
ricky.
You will expeirence boost creep with that set up meaning the car will over boost and hit fuel cut.
I would port the wastegate of the turbo and run a HKS or toyTuning actuator if I was you so boost is stable which should stop the boost getting near fuel cut.
