nerosis Posted March 6, 2009 Posted March 6, 2009 Fitted my blitz Bov and it works.But there is 2 holes left from where the old BOV was (the standard 1)What do i do with these holes? because im guessing since the BOv works fine, that i didnt do any thing wrong.Can i cork up these holes? or do i need to get a small filter thing?help please. Quote
jam-ep Posted March 6, 2009 Posted March 6, 2009 If you are using the standard EFI pipe yeh block the hole up where the standard BOV sat ( i used an old socket wrench rubber handle cut down worked a treat), and for the pipe that comes out of the rocker cover just place a breather filter on the top or oil catch tank, cant remeber if its 12mm hose you will need. Quote
Sparky Posted March 9, 2009 Posted March 9, 2009 I seen that someone put a 2 pence piece in the EFI pipe to block it at a meet yesterday!As said you would need a oil breather filter or oil catch can for the top of the engine, I was recommended a 9mm one, not fitted it yet though so cant confirm. Quote
