JM_16v Posted March 7, 2009 Posted March 7, 2009 my s/s manifold has a nice crack after 1 month so im going to put the standard one back after i see if the new one can be repaired.whats do you recomend me to do to remove it? can i just remove it without removing the turbo etc? Quote
Markoos Posted March 7, 2009 Posted March 7, 2009 my s/s manifold has a nice crack after 1 month so im going to put the standard one back after i see if the new one can be repaired.whats do you recomend me to do to remove it? can i just remove it without removing the turbo etc?You can remove it as one but i must stress that it will take so much longer and you might aawell take the turbo off aswell! Quote
paul w Posted March 8, 2009 Posted March 8, 2009 You will find it a lot easier to remove the rad, cat and turbo as the nuts at the back of the turbo are a twat to get at! If you try and cut corners you will only end up getting pissed off and it will take longer by the way forget the SS mani it will only crack again, save some cash for a mild mani then fit that instead Quote
