Ive got a
Blitz Nur Exhaust
Decat
Airfilter
BOV.
That should see me to about 140 ish *give or take a few ponnies*
What can i do next to get more BHP and also not FUCK my engine?
If i get an after market Mani and a FMIC, would i need to get anythingt o go with these, i.e a FCD? or can i just run it all like that?
I really want to start modding ALOT as ive saved up i just dont wanna blow up my new glanza. lol
I would get a HKS actuator, that way you can run a bit more boost, about .8bar (just before fuel cut)
Obviously you will need a boost gauge to keep an eye on it.
Then I would get a manifold and while fitting it get the turbo off and port the wastegate, will give you stable boost and better delievery plus you will have less chance of boost creep meaning you could run a front mount filter.
Then just get a FMIC and thats the breathing side of things sorted, should see 160 brake or maybe a bit more then
Thats what I got to do this weekend!!
Forget the FCD too they are shite unless set up by someone who knows the crack with them....not many people do :p
