starlet virgin Posted March 22, 2009 Posted March 22, 2009 hi got a 1996 glanza turbo and would like to no how to fit these spark plugs little guild would help cheers Quote
mattgtt Posted March 22, 2009 Posted March 22, 2009 quick listremove top mount intercooler if you still got one its got 4 mount bolts and 1 bonding wire and the 2 hose clamps.then just pull leads out of the tubes and you will see the top of the plugs use plug socket to remove plugs. re fit new plugs not too sure on torque figure was a wile since i fitted mine.replace leads making sure they 'click' into place on top of the plug.and re fit topmount replacing 4 mount bolts 1 bonding wire and both hose connections.when your happy start her up making sure she runs smooth no missfire or excessive vibration and check there is no leaking around the re fitted hose connections. and if all good, then good times!! Quote
starlet virgin Posted March 24, 2009 Author Posted March 24, 2009 quick listremove top mount intercooler if you still got one its got 4 mount bolts and 1 bonding wire and the 2 hose clamps.then just pull leads out of the tubes and you will see the top of the plugs use plug socket to remove plugs. re fit new plugs not too sure on torque figure was a wile since i fitted mine.replace leads making sure they 'click' into place on top of the plug.and re fit topmount replacing 4 mount bolts 1 bonding wire and both hose connections.when your happy start her up making sure she runs smooth no missfire or excessive vibration and check there is no leaking around the re fitted hose connections.and if all good, then good times!!cheers mate thats great Quote
