Could be......leads, dizzy cap + rotor arm mabe worn
was the timing belt done recently?
no, would the timing playing up explain the up and down revs? because when warmed up in settles.
the problem i have now is the cold start idle, it starts up and stays on normal idle instead of idling at about 1200 rpm.
so basically runs like a sack of shit when i start it up in the morning.
it has to be something electrical, a sensor as you said before, but i cannot seem to narrow it down.
as i said before, it runs spot on once its warned up.
cant be the timing...it would hunt all the time...
what are the plugs like?
the last owner changed them before i bought it,
would the wrong type of plugs cause the auto choke not to kick in?
he might have brought the wrong ones
