i want to know if a misubishi evo engine will go into the glnzas, I've seen the video on youtube with the white ep82 with it in, but never in a glanza.
i would think theres going to be alot of work involved in doing it.
yea it will fit but your talkin alot of money and a lot of custom made gear and some modifing to the car too
it wont fit in the standard bay you would have to do alot of custom fabing, cutting to make it fit, then you got to try and change and customise the evo/ another type of running gear to drive the engine.
I recon with 25-30K you might do it
you saw how wide that ep82 was thats because of the chassis adjustments and running gear/engine going through it
it would be MADNESS if done though, that thing would shift!
