Im replacing the front engine mount with a powerflex and im unsure on how to get it off.
Ive un-done the bolt holding the mount to the car, ive also un-done the two ontop of the mount holding it to the engine..
There seems to be a stud with a nut on it on the other side... do i remove this? if so how?
Helpy help
Mitch
Done it.
For people doing this, you must jack the car up, get a long extension and un-do it from beneath the car.
To get the old bush out, saw down to the metal bushing, them hammer and punch the outer metal ring inward untill its all fecked and comes out.
Be carefull to not hit the Metal Mount as its (Aluminium?)cast so wont take a beating (Could crack/snap)
Now to do gearbox...
Mitch
