lurcho69 Posted June 1, 2006 Posted June 1, 2006 on ebay at the moment there is a 4E-FTE de cat pipe will it fit my EP82 Starlet turbo H-reg.thankyou.. Quote
ecksjay Posted June 1, 2006 Posted June 1, 2006 should do yes.got a link? might be a custom jobby. Quote
lurcho69 Posted June 4, 2006 Author Posted June 4, 2006 thankyou..by looking at it i think it would be possible for me to make a one myself im a wagon mechanic so shouldnt be that hard should it.do you think my back pressure will be down if i was to remove it i would only have the back box in the system. Quote
ecksjay Posted June 4, 2006 Posted June 4, 2006 well ofcourse you'd lose back pressure, because you're taking away a big restriction (the cat).although many people see considerable benefits with removing the cat, the loss of backpressure isnt a bad thing. Quote
Glanza_Ragger Posted June 7, 2006 Posted June 7, 2006 the easier the exhaust gasses flow out of the turbo, the better.On a n/a you wouldnt want to lose ALL backpressure as it will lose you hp Quote
ecksjay Posted June 11, 2006 Posted June 11, 2006 i have just discovered that you need to be wary of those egay ones mate, apparently the bloke has never actually fitted them to a starlet and as such they dont line up very well. Quote
Glanza_Ragger Posted June 11, 2006 Posted June 11, 2006 they do fir perfectly mate, alltho they dont come with the extra mounting bracket, so they put alot of strain on the exhaust mid. but then again, the blitz one doesnt even come with the extra support bracket so.. Quote
klyfax Posted June 11, 2006 Posted June 11, 2006 Back pressure gives you HP and NM when the turbo isn't workÃÂÂng (0-2500 rpm) and takes HP and NM after 2500 rpm...This is an exsample Quote
