laurenceharding Posted April 28, 2009 Posted April 28, 2009 this may sound stupid, but how do you remove head light units from my starlet SR?pictures would be very helpful Quote
laurenceharding Posted April 29, 2009 Author Posted April 29, 2009 i know this is very amateur of me to ask, but can someone help Quote
Lenny Posted July 1, 2009 Posted July 1, 2009 this may sound stupid, but how do you remove head light units from my starlet SR?pictures would be very helpful to swap them is pretty easy i must say. Forgot to make detailed pictures! but here is the step by step explanation:-Undo light clips, like when replacing bulbs-Remove indicator by unscrewing top little screw and pulling it the indicator forward.(The indicator is connected at the bottom with a pin in a hole (#1 on picture))-undo bolt with spanner(10mm)(#2 on picture)-the headlight is now still connected on 2 spots(#3 & #4)-on spot #3 to loosen, you have to lift the light-on spot #4 to loosen, you have to move headlight towards the indicator side(this is the reason you need to remove indicator, you need the space)-both spot 3 and 4 should come loose at the same time Quote
