im just wondering how much boost i can run.
i got a ct9 hybrid and my engine is not forged ?
im running a tong gt spec hybrid with :
mani
rrfpr
hks actuator
new fuel pump
front mount
de cat
fujitsubo exhaust
no filter
now im used to the power its producing i was wondering if anyone has turned it up to lets say 1.2 bar on the mods that i have currently.
i dont wanna have to go and buy management just for an extra .2 bar ?
so your running a bar?
i'm running the g spec hybrid on standard internals, ideally you want an emanage blue to run around 1bar to 1.2 as fueling adjustments will be needed but you can run 1bar with a rrfpr and fcd reasonably safely :wacko:
you could get an Apexi SAFC and try running 1.2bar with that to make adjustments to fueling.
Guest Enzo
hey bud im run both at a 1.1 constant. had it at 1.2 a few times you should be fine with that pressure and a fuelling checj as long as you driver your car with mechanical sympathy, eg no long prolonged periods at WOT on the motorway or bouncing it off the redline at full boost all the time.
