will Posted June 1, 2009 Share Posted June 1, 2009 alright everyone, i have a standard starlet engine wise apart from the full exhaust system and hks mushroom filter. i fancy getting a td04, but was wondering what else i need. as im guessing its not a case of just bolting it in place of the ct9 and jobs a good'unany advise would be grate, cheers all.will.(1994 gt turbo, 100,000 km on the clock.) Quote Link to post Share on other sites
starbogt Posted June 1, 2009 Share Posted June 1, 2009 alright everyone, i have a standard starlet engine wise apart from the full exhaust system and hks mushroom filter. i fancy getting a td04, but was wondering what else i need. as im guessing its not a case of just bolting it in place of the ct9 and jobs a good'unany advise would be grate, cheers all.will.(1994 gt turbo, 100,000 km on the clock.)If you buy a kit from one of the suppliers on the site then you can bolt the kit on and a fuel regulator or fuel computer or both I run fpr and a neo only running 0.8bar at present been like it for over a year now no problems. If you have the money then go for an ecu better prospects for tuning. and above 1bar you'll need injectors as standard will max out. Fuel pump good for 230bhp or there abouts. I would advise suspension and brake upgrades as it does make a massive difference.(Best mod I ever made to go with bigger turbo.) Quote Link to post Share on other sites
karls_car Posted June 1, 2009 Share Posted June 1, 2009 If you buy a kit from one of the suppliers on the site then you can bolt the kit on and a fuel regulator or fuel computer or both I run fpr and a neo only running 0.8bar at present been like it for over a year now no problems. If you have the money then go for an ecu better prospects for tuning. and above 1bar you'll need injectors as standard will max out. Fuel pump good for 230bhp or there abouts. I would advise suspension and brake upgrades as it does make a massive difference.(Best mod I ever made to go with bigger turbo.)what fuel pressure are you running?? Quote Link to post Share on other sites
molovin Posted June 1, 2009 Share Posted June 1, 2009 Im also thinking of this aswell. i was also told to get a front mount intercooler and acurator and a decent decat and down pipe all in all spend £850 Quote Link to post Share on other sites
starbogt Posted June 4, 2009 Share Posted June 4, 2009 what fuel pressure are you running??I'm running 3.2bar but mine is rich and needs a map.My total cost excluding the fuel computer was about 550-600quid everything 2nd hand... Quote Link to post Share on other sites
