Jae-Glanza Posted June 2, 2009 Posted June 2, 2009 Was Fixing the Rear fog light for the mot, i've tripped something somewhere because now my tail lights Don't work, My side lights dont work and neither do my front fogs!Assuming its a fuse, Where is the fusebox containing these fuses?normally wouldnt post but i got to get this fixed before the darkness =]Thanks Quote
Guest Enzo Posted June 2, 2009 Posted June 2, 2009 lol under the stearing wheel to the left a wee bit,the main box is under the bay to the right Quote
Jae-Glanza Posted June 2, 2009 Author Posted June 2, 2009 lol under the stearing wheel to the left a wee bit,the main box is under the bay to the rightArgggh, had a look under the trim too, must of not had a hard enough look! be right back i'll go check ;pcheers enzo! Quote
Glanza-Love Posted June 2, 2009 Posted June 2, 2009 as enzo said chap.. the main box is under the bonnet right next to the battery.the smaller fuse box is under the steering wheel.. its quite camoflaged as its such a little square but its there! Quote
Jae-Glanza Posted June 2, 2009 Author Posted June 2, 2009 as enzo said chap.. the main box is under the bonnet right next to the battery.the smaller fuse box is under the steering wheel.. its quite camoflaged as its such a little square but its there!I found it! I had the trim taken off sorting a switch for the fog light and just assumed the fusebox would be under the trim! lol idiot!Fixed it all the lighting with a replacement fuse but now the remote central locking had stopped working LOL, Anyidea which fuse that is?thanks chaps Quote
