Craig_N Posted June 3, 2009 Posted June 3, 2009 Hi There,I am having a little trouble with the idling on the Starlet it is dropping really low that low it then starts to judder and the goes up a little and stops juddering but keeps on doing this contiuously does anybody know what the problem could be.Thanks in Advance Craig Quote
Asad Posted June 4, 2009 Posted June 4, 2009 clean out all the TB components, when was it last serviced? Quote
Craig_N Posted June 4, 2009 Author Posted June 4, 2009 Not tried the ac but i will try that and it is due a service so that is going to be done. Quote
Craig_N Posted June 14, 2009 Author Posted June 14, 2009 Hi,I have changed all for spark plugs there was a slit in one of the vacuum lines sorted that and the idle is still dropping low and makes the car judder when i put the ac on it will go up then idle low after a few seconds what could this be.Craig Quote
Asad Posted June 14, 2009 Posted June 14, 2009 Whip the TB off and give it dam good clean mate, did it mine the other day made a BIG difference even took the intake mani off and cleaned it and tried to get as much gunk off the head.Replace the dizzy and rotor arm the contacts are usually really worn.....any news on your new igntn leads? which pipe was cracked? Quote
