squarepants Posted June 17, 2009 Share Posted June 17, 2009 as above. simple question lol. do the badges and bump strips have holes behind them once removed? i have seen a few starlets without badges but they could have had the holes for the re-locating pins (if they have them that is) smoothed off for all i know? i know how to remove them etc etc and i know it might peel the laquer off. as ive removed bumpstrips before.TAdan Quote Link to post Share on other sites
Guest Enzo Posted June 17, 2009 Share Posted June 17, 2009 this is the wrong section mate, in this instance your looking for TECHNICAL > Exterior Design topic moved answering you question you can remove the strips, heat them up with a heatgun if you have to loosen the glue then take a polishing wheel to the gluey residuedependant on the condition of your bodywork the paint might not match up behind it Quote Link to post Share on other sites
Curtis Posted June 17, 2009 Share Posted June 17, 2009 as above. simple question lol. do the badges and bump strips have holes behind them once removed? i have seen a few starlets without badges but they could have had the holes for the re-locating pins (if they have them that is) smoothed off for all i know? i know how to remove them etc etc and i know it might peel the laquer off. as ive removed bumpstrips before.TAdanno there are no holes behind them bud, the best way to get them off is to get the hairdryer on them an peal them off slowly so you dont peal the laquer, get some meguires bug and tar remover on the glue and with a bit of elbow greese it should all come off Quote Link to post Share on other sites
chanelle1234 Posted June 17, 2009 Share Posted June 17, 2009 it took me 5hours to take mine off lol, so be prepared for a long days work haha.chanelle x Quote Link to post Share on other sites
squarepants Posted June 17, 2009 Author Share Posted June 17, 2009 this is the wrong section mate, in this instance your looking for TECHNICAL > Exterior Design topic moved cheers i didnt know there was a technical section :S i'am still adjusting lol Quote Link to post Share on other sites
