nordonian Posted June 26, 2006 Posted June 26, 2006 since the motors packed in, theres no point having the wiper there any more, not that i ever used it. Ive had a look and removed the nut under the plastic guard where it goes into the boot lid, but from the inside i cant find any way to release it through the boot lidanyone able to help Quote
Shaun Posted June 26, 2006 Posted June 26, 2006 undo the nut under the cap then pull the wiper arm off then go inside and take the plastic trim of the boot then undo the three bolts holding the motor then remove it and unplug the plug then you need a cap or gromet for the hole left this is what it looks like.hope that helps Quote
Sparky Posted June 26, 2006 Posted June 26, 2006 WOW looks good im gna do it soon i think When is stops rainin neway!!!! Quote
nordonian Posted June 26, 2006 Author Posted June 26, 2006 i removed the bolt under the plastic cap, and removed the 3 gold screws from the motor, but the part where the actual screw goes through the boot i cant seem to get out. its never been touched since the day the car was made and im guessing its stuck in place.id didnt wanna start forcing anythin i wasnt sure about Quote
