My starlet runs 10psi, is that standard boost? It also seems to drop to about 6psi when in a high gear, flat out at high revs, is this normal?
How much boost can you run before you hit the fuel cut and what sort of power is it good for?
Guest Enzo
when its dropping boost like that sounds like you have a very weak actuater, the standard 4efte actuater is pish could be alot better and is not good at holidng stable boost
standard boost is 6psi on low and 9psi on high.
have a read at this for whats involved and how much power it will make :surrender:
clicky
get an uprated actuator to make your boost hold better and get a boost gauge to set it up properly
and read the guide enzo's posted it will help
