ok the actuator is fitted I've ajusted it about as far as it will go. the part that actuator moves is sitting about 11 o'clock and won't go anyfurther and its still only boosting to 0.4 bar.
has anyone else had this problem or can anyone help me out
I'v also fitted a greddy bcc
Thanks Jimbob
The shorter the actuator arm the more boost it will run mate
Pretty sure if you want to run .8bar the length of the arm upto the middle of the pin or hole should be around 128mm
The length on mine is about 124 mill and it still the same i can't think what it could be. It was boosting more than that on standard actuator???????
