hugorufus Posted September 22, 2005 Posted September 22, 2005 i need some help, just been to see someone who makes front mounted coolers, he has never done one for a starlet gt and has asked me to get some pictures of how other people have got the pipe work around the radiator.any photos or info would be great. Quote
DAN_GTT Posted September 22, 2005 Posted September 22, 2005 Only photos i could find are theses, good luck Quote
hugorufus Posted September 22, 2005 Author Posted September 22, 2005 Only photos i could find are theses, good luck<{POST_SNAPBACK}> thanks very much mate Quote
Guest Enzo Posted September 22, 2005 Posted September 22, 2005 here are a few 91'sthey share the same the same chassis and cross member mounts to give you a rough idea.. hope that helps Quote
hugorufus Posted September 22, 2005 Author Posted September 22, 2005 thanks enzo, any of ep82's? Quote
Guest Enzo Posted September 22, 2005 Posted September 22, 2005 fraid not..its just to give you an idea Quote
hugorufus Posted September 22, 2005 Author Posted September 22, 2005 thanks mate you have been a real help Quote
Ivan Posted September 23, 2005 Posted September 23, 2005 do you have air conditioning in your car? are you planning on retaining it? if not then you can run a cooler between the radiator (providing you use a suzuki swift gti radiator) the amount you spend on a new radiator, you will save on custom piping, and you have the added bonus or running super short runners.BoostedGT had a similar setup in his.Ivan Quote
