right washer o raise glanza bonnet
Guest Enzo
id like to know if anyone knows where to obtain the right washers to rase the rear of the glanza bonnet to help with cooling?
does anyone know?
does anyone know?
you can hollow tube type thingys from b&q's matey,failing that make an extended bracket but thats effort
do you mean like this?
i used alloy blocks about 5mm thick (x3 on each side) so that pics shows a 15mm raise
remember to use longer bolts as your oe ones may not be long enough
  • 3 weeks later...
or you could treat your self 2 a varis carbon bonnet like mine, it does the trick big time, only bout 500 ish i paid, 6week wait though from japan
i wont need a vented bonnet as i have a fmic on order from the land of the rising sun lol, this is just to do for the time being as all the hot weather lately has been killing my topmount..
mmmmhmmm
i <3 heatsoak
