i have done the whole front end converison on my starlet but the head lights seem to be facing slighty up the way
i have adjusted it as far as it will go but it might just be me being paranoid
as the glanza headlights seem alot clearer than the n/a headlights
has anyone else had this problem?
Have you checked the beam adjuster switch thingy on the dash?
headlight bulbs perfect? no fingerprints? no damged bulb? (even if its chipped/damaged the slightest it will obscure the aim and kick up)
sure there fitted 100%? headlight unitd themself perfect no damaged lense inside?
if all ^ is well i`d get it down to a MOT station and get them to check it on the headlight tester
Best of luck bud :harhar:
