depends what year of 91 it is and wather it has the puney 238mil discs or 253mil if its the latter then yes it will fit :thumbsup:
if yours is 1999 model you should have the bigger brake setup? check the diameter of you standard discs :)
have nothing to measure it with :p
the disc does not seem small, fills most of the wheel.
