Hi,
I'm tryin to find out which wire at the cig lighter is the live. I've tried using a circuit tester but i doesn't light up on either of them.
There's a grey wire and a white&black striped wire.
Any help would be great as i've got mot tomorrow and need to wire this fog.
indeed, if you hook it up to the cig lighter, it'll be an ignition live, and thus it'll be able to be switched on all the time, which is not allowed :unsure:
ideally, you should use a relay switch and take the feed from the ignition/perm live, with the signal feed coming from the sidelight feed, so that it'll only switch on with the sidelights, but you'll be sharing the load on the main/ign live feed. it's how we used to do all imports anyway.
indeed, if you hook it up to the cig lighter, it'll be an ignition live, and thus it'll be able to be switched on all the time, which is not allowed :p
alright, cheers for the heads up :unsure:
My electrical knowledge is basic so i might have to get someone to do it 4 me in that case. Seems a bit complicated.
