jayy Posted August 24, 2009 Posted August 24, 2009 hi there pepz im new to all this so hope im doin it right .lol.only noticed today that my glanza v isnt boosting right .. hits the 3 light on the dashboard but than goes to 2 lights .?.?.?. also only hittin 0.8 on boost gauge with the boost droping as you try to go faster ... any ideas .. cheers Quote
Dan Evans Posted August 24, 2009 Posted August 24, 2009 check your pipes, ie, actuator, bov, intercooler etc etc etc....if not, check for a crack in the manifold Quote
jayy Posted August 24, 2009 Author Posted August 24, 2009 check your pipes, ie, actuator, bov, intercooler etc etc etc....if not, check for a crack in the manifoldyer i pulled over and had a quick look but pipes seem fine .. goin to have a good look tomoz .. il post with more info and any more info would be great .. cheers Quote
Steve GT Posted August 24, 2009 Posted August 24, 2009 yeh more info would be greatwell if its boosting to 0.8 bar it could be fuel cut firstly. have you eliminated fuel cut eg FCD if not id reccomend doing thatother than that until we get more info what actuator you got? if its the standard ct9 actuator it might be worth upgrading as the standard ones are known to naff up a bit. so firstly id upgrade thatif not id just check everything pipes etc but if there was a major boost leak youd hear it without fail lolmore info would be beneficial lol Quote
