recently i have noticed a slight knocking from the front end of my glanza S when the wheel is turned a few degrees, its not a wheel bearing sound, any one got any ideas, im thinking worn suspension bushes or something. car has done 92000Km approx 58000 miles
Jim
Wheel bearings will creak and make a whirring noise even in a straight line.
Could possibly be a cv joint, there under most strain when steering either way.
Get it on full lock and slowly go round in a circle, if its knocking its a cv joint shot.Check the boots havent split and let out grease, because the cv joint would have run dry.
