Dstillie Posted September 2, 2009 Share Posted September 2, 2009 when using a civic radiator how do you get it to bolt on i take it you wont be able to use the clips that hold the glanza one on? are the radiator hoses the same size? also do you need a different fan?Is this the right one?Click Quote Link to post Share on other sites
motion Posted September 3, 2009 Share Posted September 3, 2009 when using a civic radiator how do you get it to bolt on i take it you wont be able to use the clips that hold the glanza one on? are the radiator hoses the same size? also do you need a different fan?Is this the right one?Clickhere some pics how i mounted the radiator:http://img194.imageshack.us/img194/4620/p1090045.jpghttp://img194.imageshack.us/img194/7344/p1090052.jpghttp://img194.imageshack.us/img194/2361/p1090055.jpghttp://img188.imageshack.us/img188/4907/p1090061.jpghttp://img30.imageshack.us/img30/6622/p1090063z.jpghttp://img20.imageshack.us/img20/2320/p1090434o.jpgi took the civic fan, the hoses diameter is the same. Quote Link to post Share on other sites
HariboV Posted September 3, 2009 Share Posted September 3, 2009 here some pics how i mounted the radiator:http://img194.imageshack.us/img194/4620/p1090045.jpghttp://img194.imageshack.us/img194/7344/p1090052.jpghttp://img194.imageshack.us/img194/2361/p1090055.jpghttp://img188.imageshack.us/img188/4907/p1090061.jpghttp://img30.imageshack.us/img30/6622/p1090063z.jpghttp://img20.imageshack.us/img20/2320/p1090434o.jpgi took the civic fan, the hoses diameter is the same.I am just asking out of curiousity, why do people fit civic radiator's? Is it to the turbo'd starlets and the n/a`s? do you get any benefit out of it or do you just do it to be abit different ? Quote Link to post Share on other sites
Sparky Posted December 12, 2009 Share Posted December 12, 2009 Most peope do it when they go TD04 as some kits dont fit with the stock rad Quote Link to post Share on other sites
