EN V Posted September 15, 2009 Posted September 15, 2009 hi can anyone tell me which turbo's are a direct bolt on to the standerd mani and decatthanxjohn Quote
mcbeal Posted September 15, 2009 Posted September 15, 2009 hi can anyone tell me which turbo's are a direct bolt on to the standerd mani and decatthanxjohnim looking at a different turbo atm and as far as im aware theres only the td12?thats a direct fit and there are a couple of versions of it and everyone has said it has no real benefits to fitting itwhat are you looking to do?replacement for a knackered ct9 or you looking for more power?other than that are the ct9 hybrids that are sold on here eg tongs gt spec.... Quote
EN V Posted September 15, 2009 Author Posted September 15, 2009 im looking for more power i had heard tat the td04 is a direct bolt oncan anyone shed any light on this Quote
mcbeal Posted September 15, 2009 Posted September 15, 2009 im looking for more power i had heard tat the td04 is a direct bolt oncan anyone shed any light on thisits not you will require a different manifold and downpipe to suit or a adaptor plate that bolts to your manifold then a custom downpipe would need to be made...then oil and water lines to be made up for it whch shouldnt be too expensive...looking at around 500 for mani and downpipe depending on what you get exactly could be done alot cheaper with an adaptor plate but will all need to be custom made but do the job well enough on all the cars I've seen with them...depends on your budget...if you can afford there are a few traders on here and tgtt that sell the whole kit. Quote
