does anyone know were the fuel pump relay is located?? im having problems getting the fuel pump to work...and it only works when i bridge the conncetions in the diagnostic port!! can anyone help me with this problem?? also when i look at wiring diagrams i cant see were the switched feed is coming from...is it the ecu....or an ignition feed??
cheers
