japcarmaniac Posted September 17, 2009 Posted September 17, 2009 my springs have been on for over a month now and have settled in but it seems the rear passenger side one is higher than the rest. its a good few mm higher and its starting to do my nut in. has anybody else seen or had this problem? could it be the shoky? Quote
ibz Posted September 17, 2009 Posted September 17, 2009 i think you will need to get an adjustable panhard rod to balance it out mate. Quote
japcarmaniac Posted September 17, 2009 Author Posted September 17, 2009 i take it that its common? Quote
ibz Posted September 17, 2009 Posted September 17, 2009 i take it that its common?yes mate, its common when lowering the starlet. need to get one myself to be honest as my car scrapes on one rear driver side lol Quote
japcarmaniac Posted September 17, 2009 Author Posted September 17, 2009 there piss easy to put on. but dont these just stiffin things up? how would it even out the drop? Quote
ibz Posted September 17, 2009 Posted September 17, 2009 there piss easy to put on. but dont these just stiffin things up? how would it even out the drop?this probably shows it better than i can explain lolhttp://www.rs-r.co.jp/products/lateral/index.php Quote
mr.tattoo Posted September 23, 2009 Posted September 23, 2009 sorry to jump in ya thread but my starlet rubs like a biatch on drivers rear but not passendger side also as the link you posted its off piste to one side, did you get the rod and did it work? any links to places to get one as i need one bad as my tyre cant take anymore lol, thanks Quote
japcarmaniac Posted September 27, 2009 Author Posted September 27, 2009 ive been told that a panhard wont fix my problem. has anybody else had this problem and if so what was the fix? im going to stick the spring on the other side to see if it does the same so i can rule it out. Quote
japcarmaniac Posted October 1, 2009 Author Posted October 1, 2009 mabey i should just get one then. ok then a rod it is. anybody got a link to a site were i can get one?cheers Quote
mr.tattoo Posted October 1, 2009 Posted October 1, 2009 mabey i should just get one then. ok then a rod it is. anybody got a link to a site were i can get one?cheersi got mine off tm dev on here, next day delivery and 5 mins to fit,whiteline one. Quote
EN V Posted October 3, 2009 Posted October 3, 2009 has anyone got a pic of where they bolt to ? Quote
Mike d ep82 Posted October 4, 2009 Posted October 4, 2009 has anyone got a pic of where they bolt to ?just look under the back of the car, you will see a long rod at an angle from left to right at the axle, thats the original rod but is non adjustable. its just a remove and replace job . measure the centre of the wheel to the front of the arch and adjust until both sides are the same length. done Quote
