my springs have been on for over a month now and have settled in but it seems the rear passenger side one is higher than the rest. its a good few mm higher and its starting to do my nut in. has anybody else seen or had this problem? could it be the shoky?
sorry to jump in ya thread but my starlet rubs like a biatch on drivers rear but not passendger side also as the link you posted its off piste to one side, did you get the rod and did it work? any links to places to get one as i need one bad as my tyre cant take anymore lol, thanks
  japcarmaniac said:
mabey i should just get one then. ok then a rod it is. anybody got a link to a site were i can get one?
cheers
i got mine off tm dev on here, next day delivery and 5 mins to fit,whiteline one.
  EN V said:
has anyone got a pic of where they bolt to ?
just look under the back of the car, you will see a long rod at an angle from left to right at the axle, thats the original rod but is non adjustable. its just a remove and replace job :thumbsup:. measure the centre of the wheel to the front of the arch and adjust until both sides are the same length. done :D
