Hi folkes My 1997 starlet sportif has started bucking and jerking, sometimes you can go 20miles and its okay, then you go just around the block and its starts jerking! it has never once let me down in 7 years, and starts first time. Weve changed the plugs, leads, fuel filter. We put some injecter cleaner in and it seemed to work as it did 1100 miles before stating again!! do you think its the injectors, how would we check them? or does anyone think it maybe something else? any suggestions would be a great help!!!!
jerking? at what sort of speed is it doing this?
Mitch
Usually when doing about 40 or sometimes when pulling away at a junction etc!
Guest dominodon
same problem in the renualt ,throttle bodie need cleaning.
Thanks for that, will give it a try.
She
