Hi all
on my GT loom for my NA conversion, there is 1 insulated white wire that goes down to a single pin plug. on my lamda sensor ( i received off a glanza with my blitz decat) it has 4 wires and a 4 pin plug. however one of the wires is the same shade of white.
ive checked under the bonet of a glanza, it has the same 1 pin plug, white insulated wire. but has 1 wire on the other end to the sensor as well??!! real puzzled me, im unsure if this is the correct lambda, or if i only used the white wire it would work the same?
i can only assume the others are for an AFR or something like this? anyone help???? i need to know, so i can tell if i have to scrap this one, and get a standard GT one from a breaker, or if i can modify this one to work by connecting the white wires together.
any help at all would be great
cheers guys
Jay
