Where does the temperature needle sit when the car is warm?
When I bought my GT the thremostat was fucked and the temperature needle wouldnt go upto half and the heaters werent the best.
If its not that the matris could be fucked but normally if they go there would be water everywhere in your foot wells.
Please post technical questions or other threads in the correct section :)
Sounds like heater matrix then, Bit of a twat of a job apprently, dash out the lot :)
Hopefully its something simple though have a dig around in the footwell area
if your getting water in the footwell then more thsn likely the matrix but when i got my car it didnt blow hot air but it was only cable had fell of from the flap stick your haed under the dash and have a look only 2 sec job to fix. the cable that is lol feck doin the matrix, block it and wear a wolly jumper
  • 4 weeks later...
lol, i have the opposite problem.
When the car is cold it will blow cold air. Once it's hot it will only blow hot air and nothing but hot air
:@ My face and feet begin to burn so i open the windows and its p*****g with rain!
Wheres the problem in that? ^ ........just turn it down/off
Turn it off fine! But when you travel faster about 50+ it blows hot air regardless and it is turned fully to the cold setting :S
