hi
i`m getting ready to fit the 7-afe T/B &noticed a 3rd fitting beside the 2 water pipes on the bottom of the throttle body which is sensor controlled vacuum called idle control. i dont recall seeing this sensor or fitting on the N/A 4efeT/B body????( i haven`t got the car nearby@the moment )
do i just block it off if there is no direct connection or where would it normally connect to on the 7afe engine ??
can anyone confirm if i need it or not
i have a microtech fitted so some of the idle control functions are limited
thanks lyle
