chr15_7_t_ Posted October 2, 2009 Posted October 2, 2009 had a problem with my car i couldnt tel you what it is but il tel you wat it is doing...it wont idle after i took it out for a wee drive(1/4mile)..but before i took it out it was idling away fine after i had put the new leads on and it was idling for about 5 minutes before i took it outwhen it died after not idling it wouldnt start and the battery was flat..i must add that the car hass been siting in my garage the past week so i had to jump start it off another car.. and when i took the screws out of the battery i could only see sum water in one o the battery resevoirs...from about 2,500rpm when i was driven it when i put my foot down a wee bit ther was a noise like a realy loud what i could only describe as tapity but this dosnt hapen when the car is not driving?you can reve it all the way to just under 8,000 when its not moving and ther is no noise?ive just channged the spark plugs and ignition leads because i thought this was the problem.any help would be a great help :D Quote
chr15_7_t_ Posted October 2, 2009 Author Posted October 2, 2009 http://www.ukstarletclub.com/forums/index....mp;#entry291034thats the thread that i had up before which has everythng that has latly been done to the car Quote
chr15_7_t_ Posted October 2, 2009 Author Posted October 2, 2009 got someone to have a quick look and its not runing on all cylinders... but yet once it has cooled down for a while you can start it back up and itl idle ok for a wee bit Quote
