I just bought a starlet glanza v turbo ep91 and noticed leak on the passenger side floor. from what research ive done i think the heater core is leaking and i was curious about how to fix it myself. any help would be greatly appreciated.
thanks.
ive been there. its a bit of a c*nt, you will have to take the dash out to get at the heater matrix you will need to replace it.
in the mean time watch yourself, you can loop the pipe that goes from the engine to the firewall. this will cut off the supply of water to the matrix and means you can drive the c ar about.
just watch yourself the now. the water thats on the floor was supposed to be for your engine so until you have looped the pipe you will need to keep an eye on your radiator otherwise your car might over heat.
heater matrixes are 120 from toyota, i have one in my shop for sale
thanks for the info. is it necessary that i buy a new matrix or can i simply replace a hose?
and it is not water that is leaking. im pretty sure its antifreeze.
yea the water/anti freeze is from the engine dude.
thats why you need to check your rad
no the matrix is more than likely bust. the only way to check is taking the dash out but the matrix is just like a mini radiator.
alright. could you give me a more detailed explanation on how to temporarily fix it (the tube twisting thing)? that way i can drive it until i get time to replace the matrix this weekend.
and are there in dangers in doing the temporary fix?
ah ok. still send your number over if you can man..
il just take some pics of what you need to do then il pm you mate
yea your phone number,
send it over in a private message :harhar:
where the two arrows are the two pipes that lead in and out of the core from the engine.
you want to disconect those pipes.
remove one of the pipes
and loop the two connections that come out of the engine so that the water/coolant feeds back into the engine.
bypassing the heater matrix.
hope that made sense
