silverglanza Posted October 18, 2009 Posted October 18, 2009 i no starlets are about 130 135 bhp say for instance i want to run 180 to 200bhp what mods would i have to get done to my glanza like would i have to change ecu ect? any one with some advice would be very helpful cheers guys Quote
Steve GT Posted October 18, 2009 Posted October 18, 2009 i believe sparky got 185 bhp with just running emanage on a standard turbo so it can be donein my opinion id get all the stage one mods done first, for example full exhaust system, manifold, decat etc then add a front mount intercooler. relocated air filter etc. then get an adjustable actuator and boost gauge and raise the boost to 1 bar. but before this you'll need either ecu or a Fuel cut defender/rising rate fuel pressure regulator combo cause boost over about 0.8 bar will hit fuel cut so you'll need to sort that out.That should get you about 160-180bhp. if you want to push near 200bhp id reccomend a hybrid turbo which will give you that extra bhp to reach 200bhphope this helps dude any more info just ask Quote
